Sponsored by: CARiD
HELP Car wont turn over!
Old Jul 5, 2008 | 03:32 AM
bmxer8699's Avatar
Default HELP Car wont turn over!
Battery is fine, all the gauges come on and the radio comes on, but when i go to turn the key the car will not turn over at all. I tried to remote start it at first, and got nothing out of it. then i tried it with the key. Nothing.. I'm at a loss of what to do, this car is my daily driver right now and I dont have another ride.
what could this be? the VATS? the starter?
All the lights and gauges are on, the car was running fine last night. And yes i did let the car sit, i took out the remote battery, pulled the battery out of the car, and let the car reset itself, and nothing works.
Old Jul 5, 2008 | 01:19 PM
BlkBird2000's Avatar
Look at all the fuses. My car wouldn't turn over the other day cause I blew the ignition fuse. My ignition wire (purple) was touching bare metal cause I did the !wire mod and didn't protect the wire from the sharp metal hole I cut. Over time the metal rubbed through the rubber around the wire and kept blowing fuses. I don't know. Maybe my screw up will help you some?
Old Jul 5, 2008 | 02:50 PM
bmxer8699's Avatar
def will check the fuses today
Old Jul 5, 2008 | 03:27 PM
bmxer8699's Avatar
its not the vats cause the security light is off.
how do i know its not the starter, is there a way to test it?
Old Jul 6, 2008 | 02:15 AM
camaroguy26's Avatar
try jumping the solenoid
