Sponsored by: CARiD
antifreeze leak
Old Jul 6, 2008 | 09:31 AM
evaninfl's Avatar
Default antifreeze leak
After warming up to operating temp antifreese drips slowly to the ground off the bottom of the oil pan behind the cross member. I followed the heater core supply and return hoses and all is dry. Radiator and hoses are dry. Water pump is dry as I trace behind the pulley. Could it still b e a water pump to leak that far back? Are there freeze plugs on the side of the block like cast iron small blocks? I have not been under car yet as I have no means until it goes to a shop. 1998 z 28
Old Jul 6, 2008 | 11:34 AM
ollyshawn's Avatar
could be your water pump gaskets leaking
