Sponsored by: CARiD
Leaking coolant
Old Jul 6, 2008 | 10:25 AM
evaninfl's Avatar
Default Leaking coolant
After car gets to operating temp and some pressure in system a slow drip of coolant falls to the ground off the oil pan 3 inches from the rear of pan. Leak stops when pressure is off or cap off . Operating temp is 190 average in Florida unless in traffic then to 200 . What could it be ? I traced all heater core lines and they were dry. Radiator and hoses are dry. Water pump seems dry and looked dry behind pulley. Is there freeze plugs or some other issue I might have?
Old Jul 9, 2008 | 02:11 PM
PAGregSS's Avatar
At the rear of the intake, on the heads, ther are hard coolant lines that screw into the head. They look just like the ones that are at the front of the intake on either side of the base of the intake.
