Sponsored by: CARiD
fuel pump issue? maybe?
Old Jul 9, 2008 | 11:13 PM
lusting4ls1's Avatar
Default fuel pump issue? maybe?
so my fuel pump was whining extremely loud after about a minute after start up and someone suggested changing the fuel filter. so i did and it did the trick. cranked it up and drove it around town or about 20 or 30 minutes and it was still quiet.
well today i had to drive it to work and i drive about 20 miles on the interstate. when i got off the exit ramp i noticed it whining again, but not quite as loud as before. it did it again on the way home. i stopped for 5 mins at a gas station and cranked it back up and no whine. drove it home and no whine. i went to the gym and back later and still no whine.
my question is, does interstate driving make the pump whine for some reason?
Old Jul 10, 2008 | 08:21 AM
stockerws6's Avatar
What year car? How many miles? Original fuel pump?
I had similar noise after 15 minutes of city driving in mine - 96k miles. I bought a new pump a few months ago but have not heard the whining noise come back and have not installed the pump yet.
Old Jul 10, 2008 | 10:58 PM
99z28, 148k, and yea im sure its the original pump. i really hope its not going out, because that has got to be a pain in the *** to replace unless you want to cut the body up. =(
Old Jul 11, 2008 | 12:08 AM
Fifedogg's Avatar
my stock one was always quiet. It will probably go out eventually. If it does just by a Racetronix kit its only a little over $200.
Old Jul 11, 2008 | 12:51 AM
LS184's Avatar
im putting the racetronix kit in mine nxt week, my car already has the hole cut in it, so install should b easy, dropping the tank can b done, but its just much easier on a lift
Old Jul 11, 2008 | 01:58 PM
ae13291's Avatar
sounds like the plastic fan inside the pump has a slight crack in it and is about to go out!
Old Jul 11, 2008 | 02:10 PM
Ntimid8r7's Avatar
Cutting an access panel is the best thing you can do! I was very leary of but went ahead and did it on my SS. Once the carpet is back in place you are the only one who knows its done. If you do it carefully and with the right stuff it will save you a major headache. I have some pics if you want them.
Old Jul 11, 2008 | 02:17 PM
samson_420's Avatar
I believe cutting the access panel is really the only way to go on our cars. It will cut down the time by about 75%.
Just look at some pics and do it. Just don't wait until it dies all the way, it will suck pushing the Camaro.
Old Jul 11, 2008 | 03:09 PM
1sick'98WS6's Avatar
+1 on cutting access pannel. just do it right and it will look nice. I used stainless hardware and a good gasket for the door
Old Jul 11, 2008 | 05:55 PM
samson_420's Avatar
Where did you get the hardware to do this?
Old Jul 11, 2008 | 09:46 PM
i would love some pics of some. i did look at a few on here. do you just leave the hole in the car or do you get some sheetmetal or something to replace it with? use silicone with it???
Old Jul 12, 2008 | 12:16 AM
samson_420's Avatar
The ones I have seen were done with a hinge. So it was like a trap door.
But, I have no idea where to get the stuff for this.
Old Jul 12, 2008 | 03:43 AM
Ntimid8r7's Avatar
you can cut it just enough to make it hinge itself and then push it back down and silicone it. do however you like but that is how I did it. a metal cutting wheel on a dremel is the best to use. when you are cutting you have to be very careful and no cut too deep since your wiring harness is just under the metal. these are all I have. the others were lost on my old computer when it crashed.
Old Jul 12, 2008 | 10:48 AM
samson_420's Avatar
Very helpful, thank you.
