Sponsored by: CARiD
Car won't turn over
Old Jul 10, 2008 | 06:05 PM
theblur98ss's Avatar
Default Car won't turn over
I just got done with some extensive mods and now my car won't crank over. I tried a new key with no luck. If I bypass the relay it will crank. I did remove the stock pcm and the wiring to/from it for a BS3 install but I don't think any of that should effect the starter. Could it be something in the vats?
Old Jul 10, 2008 | 07:23 PM
Got it fixed. Found out that I cut the wire from the starter relay ground to the BCM when I was taking out the PCM. I was being very careful but I guess not careful enough. I had a stray wire left over when I was done....now I know what it goes to.
