Sponsored by: CARiD
how do i turn off fuel pump?
Old Jul 15, 2008 | 08:34 PM
93cz28's Avatar
Default how do i turn off fuel pump?
any1 know which is the fuse for the fuel pump on a 93 z28? i cant find it anywhere and i need to turn off the pump.
Old Jul 15, 2008 | 09:30 PM
2002_Z28_Six_Speed's Avatar
If you can't find the fuse pull out the power connector at the rear bulkhead connector under the car by the rear end.
Old Jul 16, 2008 | 08:18 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Pull the relay in the fuse box under the hood
Old Jul 16, 2008 | 08:36 AM
wickedformula's Avatar
ohh yeahh
Old Jul 16, 2008 | 02:28 PM
93cz28's Avatar
i tried that but i see no relay there for the fuel pump, i checked he fuse box inside the car also and dont see it there neither.
Old Jul 16, 2008 | 03:14 PM
Formula413's Avatar
Are LS1 relays in a different place than LT1's? On mine (LT1) the relay is under the driver's footrest. You just remove the trim piece and it's right there.
Old Jul 16, 2008 | 04:38 PM
Z28/2002's Avatar
In my 94 Z the relays are under the hood on the driver's side
Old Jul 16, 2008 | 07:20 PM
93cz28's Avatar
ok i just disconnected the relays to the injectors and started the car so it would bur nall the extra fuel that was in there and then connected it again.i think one(or more) of the injectors are letting in to much gas.but i got it started again.thx for the help guys
Old Jul 17, 2008 | 07:28 AM
Z28/2002's Avatar
No problem
