Sponsored by: CARiD
Help, Rear End Noise
Old Jul 23, 2008 | 07:02 PM
noswes's Avatar
Default Help, Rear End Noise
98 Z28 6-speed, making awful rear end noise. Mismatch tires sized: 315/35/17 Rear and 275/40/17 Front. Does this affect traction control or cause any disturbance in rear end? I.E seems as though noise is not present with ASR OFF.
Old Jul 23, 2008 | 07:56 PM
Slo-Mo-Shun's Avatar
Numerically both tires have the same overall diameter. (25.6") One is just wider than the other. I can't see how that would cause a problem. If the tires were 2 different diameters, then I'd say yes... especially if you have 4 channel abs, because one tire would turn faster than the other, thus causing abs or traction control to kick in, trying to fix the difference in wheel speed.
I'm not familiar with GM's ABS or ASR system's. Although all manufacturers achieve the same result, i.e. free a locked up wheel when braking, or control excessive wheel spin.
Old Jul 23, 2008 | 08:35 PM
99345hp's Avatar
describe the noise and maybe someone can help. under acceleration or braking?? what does the noise sound like?
