Sponsored by: CARiD
Security system major headache
Old Jul 25, 2008 | 09:28 PM
paulc87's Avatar
Default Security system major headache
So between the security system and the VATS i think i am going to go nuts.
Every couple days I will try to start my car and the security system will go off and not stop no matter what I do.
Also, I did the VATS bypass and had it disabled in the computer but it still happens once in a while + the light comes on while I'm driving at random
Anybody know what my problem is? I would greatly appreciate any help
Old Aug 1, 2008 | 12:56 AM
paulc87's Avatar
bump ^^^
Old Aug 14, 2008 | 01:24 PM
paulc87's Avatar
bump ^^^
Old Aug 14, 2008 | 06:44 PM
2001NBMZ28's Avatar
Not sure what's going on here. If VATS was bypassed with the correct resistor value you shouldn't ever have a security light. Are you opening the car with the key when the alarm is armed? If that's the case you only have a few seconds before getting the key into the ignition before VATS will set the alarm off if the resistor isn't within the nominal range. Just some ideas...we're talking stock alarm/VATS right?
Old Aug 14, 2008 | 07:45 PM
samson_420's Avatar
If you are still having problems, post up some more specific information.
Old Aug 15, 2008 | 09:09 PM
paulc87's Avatar
The key I use has no resistor on it (to open the car). And I am positive I did the VATS bypass correctly.
Like today, I unlocked my passenger door from inside the car. Alarm started going off like crazy when I tried to start it, It wouldn't start until it had gone though 2-3 cycles. VATS light never came on though, it just wouldn't crank over
