Sponsored by: CARiD
***PLEASE HELP****...Cluster lights problem
Old Jul 28, 2008 | 11:20 AM
crockett_2188's Avatar
Default ***PLEASE HELP****...Cluster lights problem
ok so a few weeks ago i unhooked the battery cables to clean the post and all. after i reconnected the battery, i had several service lights come on and stay on! the "security" "abs inop" and "service vehicle" lights are all on everytime i crank up...they stay on as long as the car is running. there is nothing wrong with my car, i've checked everything i can think of and still cant get them to go off!.....can anybody give me any suggestions on how to fix this problem???
Old Jul 28, 2008 | 12:56 PM
NBM-LS1's Avatar
Check fuses.
Old Jul 28, 2008 | 02:50 PM
thanks. the fuses are fine...checked those already
Old Jul 28, 2008 | 03:57 PM
needadvice's Avatar
Take both the neg and pos battery cables off for 30 minutes. Connect the neg, then tap the pos against the pos terminal 3-4 times getting a spark each time you tap it. Then connect it and see if that fixes it.
