Sponsored by: CARiD
misfire help
Old Aug 16, 2008 | 09:22 AM
vr6dub's Avatar
Question misfire help
my CEL came on and i ran a scan on it. it came out to misfire in cylinder 3. so i replaced all spark plugs, wires, and still not fixed. i changed injectors and still has that code. i disconnect the injectors and can feel/hear a change in the motor until i disconnect cylinder 3 it doesnt do anything, im thinking something wrong with the wiring. anyone know how can i check this? or any other suggestions yall might have?
Old Aug 16, 2008 | 09:47 AM
99345hp's Avatar
You need to make sure that #3 coil is good. I would swap it with the #1 coil and see if the misfire moves. Or if you have a spark tester use that to check and see if any fire is coming out of the coil.
Old Aug 16, 2008 | 11:18 AM
vr6dub's Avatar
did that maybe that everything is good gettn spark and everything. my mech said it might be the valve thats "flammed" and doesnt make a good seal anymore.
Old Aug 16, 2008 | 01:21 PM
2002_B4C's Avatar
sounds like a good time for a comp. check You are on the right track. Good luck.
Old Aug 17, 2008 | 10:19 AM
99345hp's Avatar
^^^ x2, if it is getting fuel,air and fire, has to be compression.
