SES Light - cat needs to be replaced?
Does this mean the cat(s?) are bad? I had an open exhaust after the cat for a while. could that cause it to throw the code, or do i have to replace the cat? and is there more than one? I was under there fixing the pipe on my exhaust and i didn't see a 2nd one...
Thanks in advance.
Car is a 96 TA, LT1 + T56
P0420 and P0430 are catalytic converter codes. The cats need to be replaced. Or just cut off.
So is it definitely the 2 cats, or could it be a sensor?
If it is the cats, what is the most beneficial, but not exorbitantly expensive way to fix it and still pass emissions? I figure if I can upgrade for the same price as replacing all the upper pipe, i might as well.
P.S. I love Quasar Blue LT1s, got any pics of it?
Edit: I found your other thread with the picture. Looks great. One of those weird TA's with the Formula spoiler.
Sounds good. I figured those were my options, but I don't have a tuner so I'll probably just get a couple of cats and have them welded in because i have to get another piece of exhaust welded too. though one thing on the Magnaflow cats... Jegs list them as only suitable for cars up to 5.2l of displacement, its there going to be a flow issue on the LT1? I just don't want to rape the power if i don't have to.
http://www.planetmagnaflow.com/shop/Spun-Cat-100.html
Magnaflow also makes direct fit replacements which they claim flow better than stock, and they aren't very expensive. Try looking around online, the site I listed above didn't have them but they are available. Part numbers are 23517 = driver side, 23518 = passenger side.
