Sponsored by: CARiD
need an explanation to this SES Code
Old Oct 2, 2008 | 04:07 PM
justablur1's Avatar
Default need an explanation to this SES Code
My car has lost alot of power....i can not trace it and now it threw up a different code...
heres the exact code i got.
p0174b fuel trim system lean bank 2
let me know what it could be..thanks.
Old Oct 2, 2008 | 04:15 PM
justablur1's Avatar
bumpity bump
Old Oct 2, 2008 | 04:55 PM
2001NBMZ28's Avatar
Assume you took care of whatever other code(s) it was throwing. www.gearchatter.com/viewtopic8735.php is for P0174.
Formula413's Avatar
Be patient!!!
This means the computer detected the engine running lean (too much air in the air/fuel mix) on bank 2, which is the passenger side of the engine. Even though it only threw a code for bank 2, it would be best to start checking for something that would cause a lean condition for either bank. One common cause of this is a dirty Mass Airflow sensor. If you have a K&N or similar filter that requires oil, that oil can sometimes get on the sensor wires in the MAF, essentially hiding some of the incoming air and causing the engine to run lean. Another likely cause would be a vacuum leak. This happens when any of the vacuum lines running into the intake manifold develop a crack or loose connection, allowing "unmetered" air into the intake stream causing a lean condition. One common place for this to occur on LS1 engines is the line from the PCV valve to the intake manifold, it is notorious for cracking and causing a vacuum leak. Try running a search in this forum for that exact code or P0171 (bank 1 lean) and you will get lots of useful info.
Old Oct 6, 2008 | 04:37 PM
peterock98's Avatar
I had this on my 98 also I tighten up the bolts on the intake manifold.
Old Oct 7, 2008 | 01:32 PM
Justin93's Avatar
I just had this happen too, Turned out the PCV system I set up spring a leak and caused it to go full lean!
Old Oct 7, 2008 | 04:15 PM
justablur1's Avatar
thanks guys, im doing everything that you guys said, ill let you know when i fix it.
