ls6 swap question
Old Oct 16, 2008 | 03:37 PM
LS1POWR's Avatar
Default ls6 swap question
Hey guys im in the middle of an ls6 intake swap on my 2000 SS. what do i need to do with the egr wiring after the egr valve is removed because it just hangs there? and also what do i do with the Air pump under the drivers head light, just leave it with the wiring all hooked up or take it all out? Thanks..
Old Oct 16, 2008 | 03:48 PM
conan's Avatar
TAke the air pump and all the plumbing that goes with it out. Excess weight on the drag strip. I just took the egr wire and tucked it in the fuel injector harness with a zip tie.
Old Oct 16, 2008 | 03:52 PM
firehawk#682's Avatar
^exactly i did the same with me wires except the wire going to the ac pump i rerouted it a different way so it wasn't going right down the front of the block there. Looks better in my opinion.
Old Oct 16, 2008 | 07:11 PM
LS1POWR's Avatar
great thankyou guys.
