How does the Mezire WP wire up??
Old Sep 14, 2003 | 08:51 AM
C5kid's Avatar
Default How does the Mezire WP wire up??
I am thking of getting one of these and would like to knwo where it wires into? If some one can post a pic or diagram of how it works that would be great.
Old Sep 14, 2003 | 10:21 AM
T/A Medic's Avatar
Default Re: How does the Mezire WP wire up??
u just ground the black wire... and the blue wire u stick in a ignition on slot in ur engine bay fuse block... think mine was in the fuel pump slot
Old Sep 14, 2003 | 02:02 PM
Jorday's Avatar
You can either use the blue wire to connect directly to a switched ignition wire or you can wire in a relay to and use a switched ignition wire to turn the relay on and off. The instructions say either way is fine. I chose to tap into a power wire for the ABS that turns on and off with the ignition.
