write ups?
Old Oct 20, 2008 | 02:13 PM
FiFdYnUtz's Avatar
Default write ups?
so this weekend i will be installing my stall, and some longtubes/ory/cutout and was wondering where i could get some write ups for the stall and longtube installations...any help is appreciated, thanks!
Old Oct 20, 2008 | 02:21 PM
87gnx's Avatar
I ALWAYS search here first.
Old Oct 20, 2008 | 02:41 PM
FiFdYnUtz's Avatar
well i DID search, found only scattered lt write up's (not for edelbrock) and virtually NO stall converter write ups thanks for your time taken to tell me that though!
also i have another question (and yes i searched it) when i extend the 02 sensors myself do i just splice in wire to extend them? anyone have more info on doing this? thanks!
Old Oct 20, 2008 | 08:37 PM
firehawk#682's Avatar
here is a good how to website i don't think it has a stall install tho.
http://www.ls1howto.com/
Old Oct 20, 2008 | 11:41 PM
FiFdYnUtz's Avatar
thanks, i think i may have found a decent site for the stall write up now too..
now i just need info on extending o2 sensor wires..anyone?
Old Oct 21, 2008 | 08:41 AM
black00ssFL's Avatar
http://modernmusclecars.net/forums/a...p?do=tcinstall
Was the 10th result after searching for "how to install converter". You just need to learn how to narrow searches . Literally took me less than 2 minutes from the time I read this thread, to posting up the link.
Old Oct 21, 2008 | 08:44 AM
Just buy rear corvette sensors (bosch 13111). Or, you can swap pins on the pcm with the rear O2 sensor wires (since you won't be using them) with the fronts. That way you can just use the rear O2 connections, which have plenty of room to attach to the fronts when using headers. I had problems with the signal when I used extensions.
Old Oct 21, 2008 | 02:43 PM
FiFdYnUtz's Avatar
what is involved when swapping pins on the pcm?
Old Oct 21, 2008 | 03:06 PM
If you're not comfortable, then don't attempt. It's simply unbolting the gray cover on the pcm and remove the pins for the front O2's, and replace them with the rear O2's. This means you have to know where the front and rear pins are located on the pcm. If you don't understand what I'm saying, then don't try it
Old Oct 21, 2008 | 03:32 PM
tording99Z28's Avatar
Just get yourself some corvette 02 sensors. I did that and have not had a single problem with codes or anything.
Old Oct 21, 2008 | 03:39 PM
Bad Blue WS6's Avatar
the O2 ext just plug in to your stock connections, the "extend" longer to reach the new connector on the Y, no splicing of any kind.
Old Oct 21, 2008 | 05:06 PM
A lot of people seem to have trouble with these extensions though and throwing O2 sensor codes. I have always heard it is because the O2 sensors are farther down the exhaust path and they don't heat up to the proper temperature that they need to be to "switch". The corvette sensors are made to be farther down the exhaust path because thats how they are on the corvettes so the heater elements in them are stronger to help them get hotter. I don't know for sure if this is the true reason but it is what I have seen posted many times.
Old Oct 21, 2008 | 05:40 PM
FiFdYnUtz's Avatar
so theres no good way to splice into the factory connection and add wire length? because i dont really wanna spend $100 on new o2's if i dont need to...
Old Oct 21, 2008 | 05:51 PM
just get 2 pre-made o2 extentions for them ws6 store there like $30 for too. not splicing the plug right in. http://www.ws6project.com/user_stor/...ath=235_82_380
Old Oct 21, 2008 | 05:57 PM
Dragkid1917's Avatar
take it easy fella's... I spent 100 on my 02 sims..... It was a waste because as soon as you get a tune they can just tune em out. When i took off my EGR and AIR system, I NEEDED a tune anyway so be careful what you buy and make sure you need it.
BTW Ls1howto tells you everything you need to know, I used it on my converter, headers, cam swap, and refrenced it to make sure i took my intake off without damaging anything behind the intake i couldnt see... its a GREAT site.
Old Oct 21, 2008 | 06:22 PM
6speedWS6's Avatar
I have a pair of 02 extensions (brand new) just pay shipping charges and ill send them to you.
Old Oct 21, 2008 | 06:54 PM
No one said anything about 02 sims. I dont' know y you would buy them half the time the don't work, and you just as well get the codes deleted. We are talking about o2 extensions.
