Lifting engine
Old Sep 15, 2003 | 09:17 PM
ls1_55's Avatar
Default Lifting engine
I don't have any experience with lifting aluminum engines so I'd like a little advice from someone that has. I was planning on bolting my 2 lift chains to the uppermost inside bolt hole on the end of the heads. I don't know my mm sizes but it's about a 3/8 bolt using standard. I just don't want to break anything. Thanks, Steve
Old Sep 16, 2003 | 09:22 AM
ls1_55's Avatar
Default Re: Lifting engine
Can anyone help me with the previous question? I don't want to pull a chunk out of my heads. I will be lifting the 2 chains with a cherry picker. Thanks.
Old Sep 16, 2003 | 09:26 AM
Mustang Hat'r 2's Avatar
Are the heads still on the car?
Old Sep 16, 2003 | 09:35 AM
ls1_55's Avatar
Tne heads are on the engine which is on an engine stand and I'm ready to lift the engine and move it into the car. Thanks.
Old Sep 16, 2003 | 09:43 AM
That makes it a little more difficult. I normal do it with the larger head bolts. The holes for the P/S pump and A/C you could use those. The holes on the back of the heads are the same but I dont know how you will get the chain to clear the cowl. I wouldnt even try the intake or header bolt holes. Sorry I cant think of a good spot. You could drop the k-member put it on that the lift the car up and drop it on the motor and k-member.
Old Sep 16, 2003 | 09:58 AM
ls1_55's Avatar
Actually I am just moving the engine onto a '55 chevy chassis. It doesn't have any of the front accessories on it. Thanks.
Old Sep 16, 2003 | 10:04 AM
That should work then.
Old Sep 16, 2003 | 10:08 AM
ls1_55's Avatar
Thanks for your help.
 Michael S. Palmer
