QTP Prototype Side Exit Exhaust???
So if you guys are interested in this system i need some feed back.
What material do you want it made out of?
Stainless Steel or Aluminized Steel?
Single or Dual Oval Tips?
Do you want a light weight version or a standard version(16 or 18 gauge)
What is a target price for the system you are looking for(please be reasonable)
I also need a stock manifold Camaro to get this rolling. Mine is so far from stock that is not a good test bed. So if you are in NJ contact us.
Thanks
I did a 3.5 inch dual side exit on my transam, painted it flat black and you can't even see it unless you pop your head under the car, anything can be done if you put your mind to it. Ground clearance is good, shoot me a PM and I can foreward pic's if ya want ideas.
Slightly unrelated, I always wondered why nobody made a setup like the FLP's where you could easily swap cats in and out... like so:
http://www.jonaadland.com/Z28/Mods/Exhaust/Exhaust.html
I used 2 super 44 flowmaster's, cut the ends off and wended 3.5 inch pipe on, the exhaust is solid mounted with 2 tabs that go to where the diriveshaft loop attaches, and the front has no band clamp, thre's a good picture of how it's held on the header, with a tab on the collector and the exhaust and a small 3/8 bolt with a locknut, the exhaust slides up over the collector about 4 inches, and there's no leaks that are visable after a whole season. I measured the ground clearnace, I should have took a picture showing the measurment, but it was 4.25 inches at the lowest spot, and after looking at how it was done, we could angle the rear pipes up a touch bit and get it to 4.5 to 4.75 with the 3.5 inch pipe, just have to turn the end of the pipe a bit to aim it downward more away from the floor of the car, and it would be perfect.
I was actually talking to Rick about this at one of the cars shows when he brought out his Firehawk.
It would have to be able to work with LT headers. QTP/Kooks/ARH etc...
Ovoid pipe is the way to go.
I would prefer stainless over alum/steel, but that is just me.
I would want it to be light and it would have to pass the E-town test.
It def has to have an X pipe.
Either one pipe on each side or two coming out on the passenger side.
A nice Flat Black tip would be the hot ticket.
You could have the setup that I made done in 3 inch pipe instead of the 3.5 inch stovepipe we used, and it would tuck up a good bit better, there's black ceramis coating that is now available too, so the whole thing would be invisable unless you stuck youe head under the car.
You heard mine, it's loud, but passes etown's tech no problem with a big motor in the car.
Barry could easily make up what I had built, and if can build it in bulk and make it slightly adjustable for people (every car being a little different) I'm sure it would sell.
Hell if he made one in 3 inch and one in 3.5 inch, I'd have bought it from him rather then going to the trouble to make it myself.
Oh, and the oval piping, if you stick with round you will keep the cost down by about 25%, and the ground clearance on my 3.5 round tube setup is decent IMO, oval would have gotten me one more inch probably, but for the $, I didn't think it was worth it. You could drive around with mine and unless you like in hazard county you'd probably be fine.
Thanks[/QUOTE
Make it out of whichever would be less expensive
dual oval tips
16 gauge
$400-$500
That's exciting news. Keep us posted on the progress.
