PCM Codes, bad oxygen sensor? Help! Thanks
Old Oct 29, 2008 | 04:33 PM
Mike96z's Avatar
Default PCM Codes, bad oxygen sensor? Help! Thanks
Here are the codes I have:
P0133
Definition.
Slow response (heated oxygen sensor bank 1 sensor 1)
P0130
Definition.
11 circuit condition (heated oxygen sensor bank 1 sensor 1)
(Possible misfire)
P0128
Definition.
Coolant Temp is always low
I think I have a bad sensor in bank 1 and a bad coolant temp sensor, is this correct? I will try to do a tuneup because I think a misfire could cause the car to run rich and foul out the sensors.
Thanks
Mike
Old Oct 29, 2008 | 05:52 PM
SS1875's Avatar
Lazy sensor, time to replace it, probably need the Coolant sensor as well.
Old Oct 29, 2008 | 08:21 PM
Mike96z's Avatar
Thanks, thats what I was thinkin.
