exhaust clamps
Old Oct 31, 2008 | 03:31 PM
shdybrady1988's Avatar
Default exhaust clamps
I had the regular exhaust clamps that have the u bolt and the bracket on the bottom side. And it causes the pipe to collapse and hard to remove. Is there a clamp that does not do this?
Old Oct 31, 2008 | 03:57 PM
conan's Avatar
http://www.thunderracing.com/catalog...id=675&pcid=54
These are what i use on every thing that I didn't weld.
Old Oct 31, 2008 | 04:35 PM
i plan on welding all mine except from the headers to the x pipe. thats all.
Old Oct 31, 2008 | 09:48 PM
Bouvs's Avatar
I had a bunch of those strap clamps for my Corsa Catback. Long story short those clamps don't put down as much clamping force as ubolt clamps and will cause exhaust leaks or allow the exhaust to twist and sag. Trust me, even if you bottom out the threads and torque until your red in the face sometimes they just won't put down the force. So what solution did I find since I didn't want to use ubolt clamps for the reason you pointed out.
Stepped clamps you can find them at almost any exhaust shop or semi related business. They put pressure on both pipes and hold it secure.
worth the $
Old Oct 31, 2008 | 10:10 PM
Firehawk#286's Avatar
I put stainless steel strap clamps on. They're great, in that they don't collapse your pipes, and they won't rust. They're about $11 each though. You can purchase them at Jegs.com or locally at many stores (e.g. O'Reilly Auto Parts). About the same as what Bouvs is talking about, but he used stepped ones. You can use stepped, or you can use the kind I used, non-stepped wtih two bolts on each end of the clamp. One note, my pipes are 3", however I found the 2-3/4" clamps fit tighter/better than the 3" clamps.
http://www.oreillyauto.com/EW3/Produ...&currentPage=1
Old Oct 31, 2008 | 11:05 PM
Formulated's Avatar
AccuSeal band clamps are the best. Essentially the same as OEM, and included with many high quality exhaust systems.
Old Nov 2, 2008 | 12:10 AM
noriceinside's Avatar
i just received mine from thunder racing today. im a little concerned with sealing as well...at least my pacesetters come with u bolt clamps if these dont work out well.
Old Nov 2, 2008 | 01:06 AM
TheSilverOne's Avatar
throw the u bolt clamps in the trash
Old Nov 2, 2008 | 01:46 AM
MYSTIC-1SC's Avatar
I used stainless band clamps on my setup and have had great luck with them.
