2004 C5 LS1 - factory LS6 intake?
Old Oct 31, 2008 | 10:17 PM
Racinjason424's Avatar
Default 2004 C5 LS1 - factory LS6 intake?
I thought for sure I'd find the answer to this by searching, but I'm still not sure?? Did some or all 2004 C5 Corvette LS1's have LS6 intakes? I read one thread on here that said no and one thread that said yes? I know 01-02 came with them.. Just want to be sure (without pealing it off to confirm the bottom is flat or concave!) If so, does anybody know the factory HP and Torque ratings of a stock '04 C5? Thanks, Jason.
Old Oct 31, 2008 | 10:18 PM
TheSilverOne's Avatar
04 = LS6 intake
Old Oct 31, 2008 | 10:28 PM
Excellent!! Thank you for confirming.. Now, I am installing this motor into a first gen. Camaro, and I need to get a cable operated TB.. What should I get?? Year, size, Brand?? I see LS1, LS6, FAST, 78mm, 85mm, 90mm, 92mm... I plan on doing a cam and head upgrade and I want to get the right size TB right off the bat if possible... Thanks again, Jason.
Old Nov 1, 2008 | 12:38 AM
ae13291's Avatar
find one off a LQ4 thats 80mm stock
Old Nov 1, 2008 | 01:47 PM
FiredUpZ28's Avatar
Will that bolt onto an F body with an LS6 manifold too?
Old Nov 1, 2008 | 03:10 PM
ae13291's Avatar
yes the LQ4 tb is a factory 80mm tb. but u have to look for the early ones since the later ones had the drive by wire system
