Header installation????
Old Nov 7, 2008 | 10:27 PM
Interlizer130's Avatar
Default Header installation????
Do you have to jack the engine up to install longtube headers on a firebird or can it be done with leaving the engine as is???
Old Nov 8, 2008 | 01:50 AM
metalmechanic's Avatar
no, i just installed last week, without
Old Nov 8, 2008 | 02:23 AM
94'BLKBRD's Avatar
Jack it up by the K-member. You might need to put some wood between the k-member and jack to get the car high enough.
Old Nov 8, 2008 | 04:14 AM
ae13291's Avatar
i used some rhino ramps on the rear wheels and jacked up the front max on the jack and added wood blocks as well. to answer ur Question no i did my LT's without jacking the engine by itself, not needed
Old Nov 8, 2008 | 09:22 AM
firehawk#682's Avatar
no need to jack the engine just the car. they will slide in if you get in high enough.
