One poly engine mount?
Old Nov 8, 2008 | 10:59 AM
ws6ed's Avatar
Default One poly engine mount?
I've had LT's on my car for 3 years with no issues, but since I installed a cam the drivers side header now sometimes rubs the k member due to the engine shaking at idle. I was going to pull the d/s header off to grind down where it rubs and touch up the place on the header where the coating wore off. I was thinking that while I had the header out I would replace the d/s motor mount with a Prothane poly piece, but really don't want to pull the pass. side off too. (#$@%! #8 spark plug!) Would It cause any problems or increase vibration to run just one poly mount?
Old Nov 8, 2008 | 11:40 AM
Zzzzz's Avatar
Shouldn't have an issue running one poly/one stock - keep the second around and put it in once you're ready.
Old Nov 8, 2008 | 12:21 PM
00SSLS1's Avatar
not at all, I did that for awhile before putting the passenger side one on.
Old Nov 9, 2008 | 08:00 AM
LS1W66's Avatar
I'm running one poly and one stocker aswell with a poly trans mount and I have no issues.
Old Nov 9, 2008 | 10:31 AM
DaveX's Avatar
It won't hurt anything. The pass side is a little easier to swap out though, I'd prob go ahead and do both.
Old Nov 9, 2008 | 10:59 AM
jrob56's Avatar
i dont think it would hurt anything but that seems lazy as hell, just do both of them while you in there...
Old Nov 9, 2008 | 01:21 PM
94'BLKBRD's Avatar
I've heard a lot of people run only the drivers side poly mount because the passengers side really doesn't make a difference.
Old Nov 9, 2008 | 01:45 PM
CranMaro99's Avatar
I've heard this too.
 Michael S. Palmer
Old Nov 9, 2008 | 03:18 PM
firehawk#682's Avatar
I was going to do that but i figured i bought both i just as well install both and it really wasn't that much more work.
Old Nov 9, 2008 | 04:38 PM
DaveX's Avatar
The passenger side does make a difference but some might get away with only doing one side. I did the driver's side first and my Y still hit just not quite as often. So I did the passenger side and it seems to have made the difference.
Old Nov 9, 2008 | 04:50 PM
rollinna65's Avatar
I started doing my motor mounts and by the time I was done with the driver's side I was pissed off enough that I said screw the other one. I only did it to stop my exhaust from banging and the one mount did that.
Old Nov 9, 2008 | 05:22 PM
noriceinside's Avatar
yeah i think im only going to do my drivers side to. cuz how often do you floor it in reverse?
Old Nov 9, 2008 | 05:43 PM
jrob56's Avatar
um y would that make a difference? r u saying the engine turns the other way in reverse...
Old Nov 9, 2008 | 05:48 PM
of course not but it will move the other way. go check it out. thats how you check which motor mount is bad. load the engine in a forward gear then load it in reverse.
Old Nov 9, 2008 | 05:50 PM
Full-Force's Avatar
The driver side of the engine tries to come up under acceleration and the passenger side presses down. The weight of the engine already has the passenger side pressed down so yes, the driver side mount does the most to control engine movement.
Old Nov 9, 2008 | 06:41 PM
ws6ed's Avatar
thats what I figured- the drivers side does the most. I will just wait until winter when the car is put up to do the pass side along with a bunch of suspension mods
Old Nov 9, 2008 | 07:16 PM
jrob56's Avatar
ya ur right, that makes sense now that i thought about it more
Old Nov 11, 2008 | 10:39 PM
i just swapped my drivers side mount with a prothane and it solved my y-pipe banging problem.
score.
Old Nov 29, 2008 | 02:23 PM
metalmechanic's Avatar
that # 8 plug is fairly easy from the bottom
Old Nov 29, 2008 | 09:36 PM
Michael02hawk's Avatar
I've heard, I've heard, I've heard....bla bla bla...
Do it right the first time and swap out both mounts. It is a PITA, but thats the price we pay for our cars.
...and WTF is this about reverse and the passangers side motor mount?
My god, the crap that turns up on here sometimes!
