car wont start
okay I have a big problem here my car wont start ...i had to push the car in reverse to pop the clutch for the car to start.the power of the battery is good all gauges read normal so i took out the starter the guys at kregan said the coil was bad on the starter so i got a new one and i got a new battery at sears for the hell of it installed them both back in but NO GO car wont start agian had power everything normal in the car . now i have no clue what it could be when i had the car running i turned the ingiontion on to see if it would make sratching sound and it didnt make that sound ( this was before i put the new starter in ) any help would be great guys thanks
j/k
So the starter is not turning over at all? You said you push started to car (correct) so that means the engine is not the problem. Since you said you "pop the clutch," I am guessing its a M6 car. It could be the little sensor/switch on the clutch peddles (keeps you from cranking the car with the clutch engaged).
If you can get the car started and get out on a highway/open road, see if you can set the cruse control. If the sensor/switch is bad, the cruse will not engage (the computer will think the clutch peddle is pushed in).
thanks for your guys help and the quick response
don't feel bad.....a few months ago I had my reverse lockout on my M6 "die" (couldn't go into reverse) so I went through all the work of pulling the trans mount and lowering the trans to get the lockout solenoid out. When I got inside to test it..."CLICK"....it worked....
so my mom goes "do you have any fuses burned out?"
AHHHHHHHHHH.....3 hours wasted for one stupid fuse!!!
