true duals, got questions
How about getting the car inspected, I had a hard time getting my car inspected because of the window tint and ended up going having my tint redone because I could not find any to pass my car.
I was told that if i put LT on my car it would not pass inspection even if I had cats because they would be moved. What do you all you guys do that have LT's?
Thanks
long tubes move the cats so are therefore illegal everywhere...technically.
but not everywhere checks, some only check for the actual emissions in which case a set of cats will remedy the problem.
most get around the issue with LTs by either adding the cats, or living in an area that doesn't have emissions checks.
i put a similar setup on my ls1...but 3"...with magnaflow 4x9" mufflers. sounds awesome!!!
