free ram air mod hypothesis.
So best way to do it for a TA/Formula is:
1). WS6 hood + BG ram air kit
2). FTRA/SSRA + FRA (you actually do this as part of the installation instructions)
Those will give you a nice ram air affect at higher speeds. If you don't ever want to get the BG ram air kit ($300) then the FRA mod won't hurt or help your performance. The FRA only helps if you have a non-WS6 or if you are going to use an aftermarket kit like FTRA or SSRA.
I still say that the FRA and hood ram air combined makes the inlet charge warmer than the nostrils alone.
