oil pan
I found it easier to do the pan with the motor hooked back up to trans. I unbolted the mounts, lifted the motor, put a steel bar on some blocks across the fenders and chained up the motor, then dropped the k member. I want a Tubular K Member after doing all that work.
I didn't pull the front cover off while doing this. I don't see a way of doing it without pulling the motor or dropping the k-member. The pickup goes down through a fairly small hole in the windage tray, so the pan pretty much has to be lowered straight down.
Overall not much fun, but not the worst thing i've done. It'd be a good time to do poly mounts while you are in there..
front cover leak not oil pan
