smaller pulley
Old Nov 19, 2008 | 05:27 PM
CayenneRedV6's Avatar
Default smaller pulley
I'm a little confused about the over drive alt pulley. If an under drive crank pulley makes the alt spin slower then wouldn't you want a smaller alt pulley also? I thought the smaller pulley made it spin faster. Or is it the other way around?
Old Nov 19, 2008 | 06:13 PM
Dan Stewart's Avatar
Smaller "driven" pulleys result in higher revolutions at a given belt speed and require more force to turn the driven pulley. Larger driven pulleys result in lower revolutions at a given belt speed and require less force to turn the driven pulley.
Old Nov 19, 2008 | 07:50 PM
OK so the overdrive pulley is actually smaller then stock and an underdrive pulley is bigger then stock? I'm so confused.
Old Nov 20, 2008 | 12:11 AM
BackinBlack02SS's Avatar
A smaller crank pulley will turn the accessories slower. The driven accessories work opposite. For example, a power steering pump or alternator will turn FASTER with a smaller pulley. Many companies offer a larger overdrive alternater pulley along with an underdrive crank pulley to keep the voltage from dropping.
Old Nov 20, 2008 | 10:22 AM
Gotcha, thanks.
