1998 AIR Quick question??
Old Nov 21, 2008 | 03:54 PM
Nuckollsinc's Avatar
Default 1998 AIR Quick question??
I just installed hooker headers and ory and took off all the AIR and egr. Now my question is I searched for an hour and couldnt find a answer. They talk about a little hose that goes to the intake and a bracket that bolted to the intake. My car does not have no such things anywhere and the cannister looking thing thats at the t fittinf is no there either. Im a just a jackass or am I missing something?
Old Nov 21, 2008 | 04:31 PM
The hose that everyone plugs with a srew is what I cant find and the thing in goes to. I didnt know if a 98 ls1 is diffrent then any other year?
Old Nov 21, 2008 | 05:11 PM
Pushead's Avatar
From the header to the intake? That would be the EGR.
The AIR and EGR mount to the brackets (both have plates in this picture). The EGR bolts onto the head, which you can see on the right side of the picture. There is a hose that goes into the top of the intake, right behind the throttle body. If you replaced the LS1 intake, it's quite possible that you don't have a hole for the EGR.
The hose that people plug with a screw is probably the coolant line to the throttle body. You can see it in this picture. It's the thin tube just to the lower right of the TB.
Old Nov 21, 2008 | 05:18 PM
jrpimp00's Avatar
If your talking about what I think you are. Its a vacuum line and 98's dont have it we have a self contained air unit. All you need to do is disconnect the two manifold connections for the air and take out the air unit itself. Hope this helps
Old Nov 21, 2008 | 05:21 PM
Thats what i was hoping that the 98's didnt have that little vaccum line.
THANKS ALOT jrpimp00
Old Nov 21, 2008 | 06:00 PM
firehawk#682's Avatar
yes the 98 didn't have it.
