Harmonic Balancer Flew off!?!?!?
Old Nov 26, 2008 | 04:59 PM
fauslpss's Avatar
Default Harmonic Balancer Flew off!?!?!?
I feel kind of stupid for posting this But My Harmonic Balancer walked its way off the snout of the crank!!! Im driving home for THanksgiving and I start to hear the belt so I stop and check and it looked as though the HB was wobbling but I figured it was a illusion. Allmast got home and I just jump on it to clean it up after puting down the highway and after I let off I heard a loud clunk under the hood so I stoped and looked and the HB was gone. I found it but HOW the hell did it just come off I dont know if its my fault or the manufacturer's. And is there any one in the Lakeland area that has a stocker they can give me or something I just dont know how this could of happened????? Its a ASP pulley Thanks for any help.
Old Nov 26, 2008 | 05:19 PM
00SSLS1's Avatar
is your crank bolt still on?
Old Nov 26, 2008 | 05:46 PM
fauslpss's Avatar
No it came out before or with.
Old Nov 26, 2008 | 06:52 PM
HMERacing's Avatar
Your not the first. Multiple things could have attributed to this. Stock crank bolt was re-used, The final torque spec was not met, Could have been both. Bad thing is when they come off like that it can destroy the pulley and if it was wobbling chances are that is is now damaged. not to mention the damage of it hitting the pavement, ect.
Old Nov 26, 2008 | 06:58 PM
Lt1Porsche's Avatar
Seen it before. But it definitely is an error upon installation.
Old Nov 26, 2008 | 07:12 PM
steveo346's Avatar
has happened to a few guys here locally and its always contributed by them re-using their stock crank bolt....
if you used your stock crank bolt on your underdrive pulley,thats prolly what caused it
Old Nov 26, 2008 | 08:05 PM
fauslpss's Avatar
Stock crank bolt what else is there to use? I used A new one, I torque'd it as far as I could untill it was moving the car. Im not sure I can get any tight'r then I did.
Old Nov 26, 2008 | 08:19 PM
ls2 bait's Avatar
its from not putting it on correctly. if it isnt fully seated on the crank it can easily walk off. ive seen it happen on numerous cars. you should install it with the old bolt at 240 ft lbs, then remove the old bolt and put the new one in and torque it to 37 ft lbs. after that mark it or use a degree wheel and then turn it 140 degrees further. it is going to feel like you are going to snap it but its actually just stretching the bolt. i always use some blue loctite as well just for insurance. dont use red you will never get it out.
Old Nov 26, 2008 | 08:36 PM
jsteele90's Avatar
i used a 3/4 inch breaker bar and a big *** pole to do my friends still didnt get all of the stretch on the bolt we were supposed too.
Old Nov 26, 2008 | 09:43 PM
Weezzer's Avatar
Don't forget the HB has to have a recess/offset distance measurement between 0.094" to 0.167" between the face of the HB and the face of the crank, you will need to certify the exact dimension/operational parameter with the Helms manual, its been awhile and I can't be sure I remember the distance exactly.
Old Nov 26, 2008 | 09:55 PM
Weezzer's Avatar
Originally Posted by ls2 bait
...it is going to feel like you are going to snap it but its actually just stretching the bolt...
Actually the operation is designed to take the bolt beyond the 2% elasticity range and into the plastic range of deformation (stress/strain diagram). The procedure is designed to raise the clamping force of the bolt head to its maximum; however, it’s a one shot deal. It’s why they tell you to use a new bolt the next time around as the bolt has been permanently deformed.
Old Nov 26, 2008 | 11:29 PM
ls2 bait's Avatar
thank you for "technically" defining what i just said.
Old Nov 27, 2008 | 01:26 AM
scottHMT's Avatar
i got a new stock bolt i'll sell you for 10 bucks shipped
Old Nov 27, 2008 | 01:59 AM
the_merv's Avatar
Veteran: Air Force
You can get them at the Dealer for $5..I've bought a few..
Yea, it's a mother ****** to get that thing on, I have used a 3ft 3/4" Drive Breaker Bar to put it on, and it's a good little feat.
The Stock Head Bolts are the same way, they stretch once, then they are done.
Old Nov 27, 2008 | 02:23 AM
7camaro7's Avatar
a buddy of mine's asp fell off a few months ago and he was just cruising... I pretty much saw it happen. I've got the same pulley on my car and mine is doing just fine. I pray it stays that way!
Old Nov 27, 2008 | 06:51 AM
Weezzer's Avatar
No problem, I wanted you to get it right.
Old Nov 27, 2008 | 07:39 AM
z28boy's Avatar
Might want to check and retap the threads. I had some one around here put one on for me, long story short I couldn't figure out why I kept going through blower belts. I tore the hole thing apart and found a lose crank bolt and as well as damaged threads. Take your time and do it right.
Old Nov 27, 2008 | 12:18 PM
fauslpss's Avatar
Thanks Guys for the help
Old Nov 27, 2008 | 04:53 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That's the exact way to do it. Just make sure you have a torque wrench that can go to over 240 ft lbs. Mine goes to 250 and it feals like it's going to break when you're torquing it. You can also use an ARP bolt that is reusable.
Old Nov 28, 2008 | 12:01 AM
SOMbitch's Avatar
Eat some sausage n gravy biscuits so you can put some A$$ on that thing.
Actually LS2bait nailed it on the head and must have been reading the Haynes Manuel
That damn bolt looks so simple and has been a huge PIA for almost everybody here when doing the first cam install
As my old friend "Pap Parker" used to say, "I would rather sandpaper a wildcats a$$ than"...............
