throttle cable?
Old Nov 28, 2008 | 08:19 PM
ja02ws6's Avatar
Default throttle cable?
Hey guys I just got my Weiand intake on my car and got to checking everything...the throttle first and some reason I'm not getting full throtlle. Is there some way to adjust the cable or did I do someting wrong? Thanks for any input Jason.
Old Nov 29, 2008 | 12:14 AM
OMGls1jz's Avatar
you can try the bump stop mod, if that doesn't work i remember some one talking about adjusting the throttle cable but i'm not sure how its done.
Old Nov 29, 2008 | 04:44 AM
the_merv's Avatar
Veteran: Air Force
Bend the Gas Petal more..
Old Nov 29, 2008 | 08:05 AM
DaveX's Avatar
There is an adjustment in the cable. It is a black, rectangular looking thing about midway between the firewall and TC box or TB. You pull out a clip, slide it back and forth to adjust, and reinstall the clip. If you accidentally pull on the cable while working on the car it can move and needs adjustment. I had the same problem.
Old Nov 29, 2008 | 09:49 AM
RZRSEDGE's Avatar
Same as above. Just adjust the cable length a little at a time. It helps if you have someone in the car to hit the gas pedal every little bit and see where you are at.
Old Nov 29, 2008 | 10:14 AM
the_merv's Avatar
Veteran: Air Force
I was saying mine for those of us that don't have TCS..and that I have never seen what you guys are talking about..
Old Nov 29, 2008 | 11:22 AM
devilsalmostfree's Avatar
lets go jason get that thing fixed! ill help ya out tomorrow if ya need me to!
