Edelbrock Valve Covers
Old Jan 14, 2009 | 07:39 PM
  #41
The Alchemist's Avatar
UNDER PRESSURE MOD
Originally Posted by tim99ws6
Just heat the fuel rail there with a torch and bend it up....problem fixed....
That's a complete joke for the other's that search and find this thread later!!!! DO NOT DO THAT
It's actually not a bad idea, except that I plan to pull the fuel rail and empty it completely prior to putting any heat to it.
Old Jan 14, 2009 | 08:01 PM
  #42
tim99ws6's Avatar
Honestly, aftermarket fuel rails are cheap enough these days. just but and run aftermarket rails.
Old Jan 14, 2009 | 08:11 PM
  #43
UNDER PRESSURE MOD
Are they? Every where I look, it's not just the rails, but all of the fittings to get it to hook up to the facotry line that gets expensive.
I was searching around today, and it looks like it's going to be around $400 to get the rails, lines, and fittings.
If you know of anywhere cheaper, by all means hit me up with a link. My only preferance is no red or blue fittings. Black or silver only.
Old Jan 14, 2009 | 08:37 PM
  #44
tim99ws6's Avatar
yea, the black/silver fittings are a bit more money, but $400?! how much are you spending on the rails? I've got the nasty nate rails i need to get rid of if you want them for cheap($75). You'll still need to fab up the fittings part.
I agree the aftermarket rails is obviously more money than modifying the stock rails, but man, they will look a lot better than a stock rail. Regardless of performance.
I guess worst case scenario, try and modify your stock rail, and if it doesn't work, go aftermarket.
Old Jan 14, 2009 | 08:44 PM
  #45
UNDER PRESSURE MOD
What color are your rails? Black? Silver????
Old Jan 14, 2009 | 08:49 PM
  #46
UNDER PRESSURE MOD
And I agree, I think going with a new set of fuel rails is the way to go. Hell, these are an appearance mod, so why not add a little more eye candy and do it right.
