Where to mount oil temp guage sending unit?
Old Dec 4, 2008 | 09:47 PM
03 BUSA's Avatar
Default Where to mount oil temp guage sending unit?
I already have a autometer oil pressure sending unit mounted remotely to the block on top of the oil filter to the frame rail by the front of the motor. I would like to install an oil temp guage, my thought was to use a tee and have it mounted with the autometer sending unit (not the factory). However, since this is a pressure gauge and no return and remote mounted would it work for a good spot for the temp sending unit? My thought was it might give lower then accurate reading being the oil does not circulate thru the pressure line and the fact it is remote mounted, am I wrong? If we are talking a difference of a couple of degrees than fine but if it will not work let me know what you guys have done in the past. I am trying to have a nice clean install without drilling into the oil pan or running a signal wire all around the motor. Thanks again.
Old Dec 4, 2008 | 10:25 PM
camaro468's Avatar
there in a write up on were to put them i put mine in the pice that unbolts above the oil filter u have to drill and tap it do a search thats how i found how and were to mount check this out
https://ls1tech.com/forums/generatio...mp-sender.html
http://www.xse.com/leres/ss/images/cover-sm.html
Old Dec 5, 2008 | 08:24 AM
03 BUSA's Avatar
Thanks but I have that already done for the oil prerssure guage =. Wanted to know if I tee off of that and install the oil temp as well.
Old Dec 5, 2008 | 10:14 AM
03 BUSA's Avatar
What are my options with mounting a T off of the factory style oil pressure gauge? Seems hard to find a 16 MM tee that I could use to go to 1/8 or 1/2 npt??
Old Dec 5, 2008 | 10:19 AM
03 BUSA's Avatar
Also, I could use a sandwich adapter but I prefer to do the tee method off the factory sending unit.
Old Dec 6, 2008 | 11:18 AM
03 BUSA's Avatar
Anyone??
