Missfire after removing AIR pump
Old Sep 25, 2003 | 06:13 PM
blk~2000~Z28's Avatar
Default Missfire after removing AIR pump
Removed my AIR pump and all the hoses and now I have a missfire on cylinder 2. I did unplug my wires from a few coil packs to check header bolts and for clearance issues. I removed the vacuum tree from the top of the engine in the back. I did not replace the 15mm bolt though. I also plugged the little vacuum line that went into the tree. Everything got plugged back in and nothing except the AIR system are back to orginal postion. What could cause this sudden missfire?
Old Sep 25, 2003 | 06:59 PM
Default Re: Missfire after removing AIR pump
Must have been a loose plug wire, for now it has disappeared.
