LS1 oil sender ohm range? anyone know?
Old Dec 9, 2008 | 07:34 AM
Speed Demon's Avatar
Default LS1 oil sender ohm range? anyone know?
Look to add an aftermarket pressure gauge for my motor swap. I didn't get a response in the conversions/hybrids forums.
Any know the ohm range of the stock oil pressure sender?
Old Dec 9, 2008 | 08:34 PM
S10xGN's Avatar
Don't know, but what I did on my S-10 swap was a bench check. I had the sensor wired up to a VOM while adjusting the "pressure" with an adjustable air pressure regulator. I mapped it every ten lbs of air pressure and charted it in Excel.
Russ
Old Dec 9, 2008 | 09:52 PM
Russ
Is this for an LS1 stock pressure sensor? If so what where your results?
Old Dec 10, 2008 | 08:17 PM
S10xGN's Avatar
No, not the LS-1 sensor (just trying to give you an idea), mine was the stock S-10 sensor. I'm running a turbo Buick V-6 and wanted my stock S-10 gauges to work. Anyways, here's what my graph looks like.
Russ
