What underdrive pulley to buy?
Old Dec 10, 2008 | 10:03 PM
BackinBlack02SS's Avatar
They reduce drag by slowing down the accessories thereby freeing up lost HP. You can purchase overdrive pulleys for some applications. You may want to go this route if there are issues from something turning too slow.
Old Dec 10, 2008 | 10:18 PM
1MeanGreenZ28's Avatar
Wow, already a lot of responses. Sweet, so an SLP or ASP would be fine?
Old Dec 11, 2008 | 06:28 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I have the SLP, love the high retaining wall, running on a stock belt tensioner w/ 44k on it with no issues. It is SFI cert as well.
Old Dec 11, 2008 | 08:10 AM
dre2013's Avatar
i think im gonna run the summit one..mainly b/c summit racing is only 15min away from me
Old Dec 11, 2008 | 09:07 AM
on2's Avatar
on2
I say go for the Summit/eBay/BBK pulley. Because it's the cheapest, best looking, has high retaining walls, clearcoated, and is SFI approved.
Old Dec 11, 2008 | 05:55 PM
01ssreda4's Avatar
and the heaviest too i believe, not that it makes that much difference.
Old Dec 11, 2008 | 11:27 PM
on2's Avatar
on2
From what I've read the ASP pulleys weigh 10 lbs. 1.5 lbs difference is not going to be felt. It is the 25% underdrive that increases the power and response.
Old Dec 12, 2008 | 12:37 PM
Fast Toys Performance Parts's Avatar
Weight is the enemy of performance. Reciprocating weight is an even worse enemy
Old Dec 12, 2008 | 04:59 PM
FireSilverLullaby's Avatar
Originally Posted by toothdoc
That is a good deal, but I don't know if you want to get the alternator pulley for an A4 though.
I was thinking of getting an under drive pulley, why shouldnt i get the alternator overdrive one as well? my lights dim a little when my music is up real loud, so i dont want any less power from my alt.
Old Dec 14, 2008 | 09:51 PM
Well, it looks like this thread is really growing. Thanks for all the advice and please keep the responses coming.
Old Dec 14, 2008 | 11:50 PM
00Corvette's Avatar
I was gonna ask the same question, cause I have an A4 and was considering an UD pulley but also have an 1100 watt stereo...
Why not use the bigger alt pulley?
Thanks so much!
Donnie
Old Dec 15, 2008 | 12:25 AM
  #32
ZMONSTER!'s Avatar
Ill be going with the summit when I get one.
Old Dec 15, 2008 | 01:25 AM
  #33
Thanks so much!
Donnie
I would try it without the overdrive alt pulley first. If you need more voltage, go ahead and install it.
Old Dec 15, 2008 | 03:52 PM
  #34
yeah i think my stock alt is at its limit right now so im probably gonna go ahead and get the overdrive alt pulley too.
Old Dec 15, 2008 | 04:05 PM
  #35
Default ASP Pulleys
If you order an ASP pulley from us, you can specify an under driven or over driven alternator pulley.
Generally, M6 cars can get away with the under drive crank and alt pulleys as long as they are not running some killer stereo.
Auto's generally just go with crank only unless they are stuck in traffic a lot at idle and have a lot of current draw (stereo etc).
Thanks!
Old Dec 15, 2008 | 05:53 PM
  #36
It's very simple. Stock A4 idle is 550 rpm. Stock M6 idle is 800 rpm. Using simple math you SHOULD be able to slow down the accessories 31.25% on an M6 with no problems.
Old Dec 17, 2008 | 06:56 PM
  #37
MYSTIC-1SC's Avatar
The SLP pulley looks like a nice piece, probrably going to go with it when I purchase my underdrive pulley.
Old Dec 17, 2008 | 07:39 PM
  #38
blakern's Avatar
why not use the alternator pulley on an A4?
I have the march.
Old Dec 17, 2008 | 09:35 PM
  #39
Ksths2's Avatar
i've heard that C5 vettes require a different underdrive crank pulley compared to a F-body. Is that true? and why if it is.... Thanks!
Old Dec 17, 2008 | 11:18 PM
  #40
Yes, it is due to different serpentine systems.
