CAR PAUSES
Old Sep 25, 2003 | 11:42 PM
KEVWS6SPEED's Avatar
Default CAR PAUSES
I GOT A 98 TRANS AM WITH NO CATS AND AND AFTERMARKET EXHAUST
WHEN I DRIVE IT, IT MAKES A HESITATION FEELING AND IF I STEP ON THE PEDDLE IT SHAKES ALOT!!!
ANY IDEA? THANKS KEV
Old Sep 26, 2003 | 01:32 AM
blk~2000~Z28's Avatar
Default Re: CAR PAUSES
Are you getting any SES codes. That would be my first place to check. Just today after taking out my AIR system I disturbed my plug wires which developed a missfire. It acted exactly the way you described. If you do not have access to a diagnosis tool, check the plugs they may need to be changed. Then go from there.
Old Sep 26, 2003 | 06:18 AM
Hannibal's Avatar
Check the throttle position sensor on your throttle body. Mine would rev hard then just fall on her face - then catch herself and act normally. Would feel like the car lost all power for a split second. Also when just cruising - if it did it - the car would jump around then act fine.
Turn your car on and let it idle and play with the sensor and wires to see if that does anything. If its bad - its an easy fix.
Old Sep 28, 2003 | 02:31 PM
thanks guys!! i will try and let you know what i come up with , peace
