where is there a hole to run the fan switch ? in the firewal
Old Sep 27, 2003 | 02:40 PM
1RawTA's Avatar
Default where is there a hole to run the fan switch ? in the firewal
Hey guys, im doing my manaul fan switch right now, and needed to know where there is a hole in the firewall to run the switch through?????????
Old Sep 27, 2003 | 02:43 PM
NightHawk's Avatar
Default Re: where is there a hole to run the fan switch ? in the firewal
If you remove the PCM, there is a hole that you can run through. Another option would be to run through the door jamb area and into the cabin.
Old Sep 27, 2003 | 04:40 PM
2000FormulaHawk's Avatar
Under the pcm on the pass. side. You will have to remove the pcm for best clearance. If you do that you will need to do the idle relearn trick.
Old Sep 27, 2003 | 06:52 PM
BobP's Avatar
You can do it without removing the PCM. Straighten a clothes hanger and sharpen the end, then tape your wire to the tip. Carefully poke it through the existing hole in the grommet beneath the PCM. There's your wire .
BobP
Old Sep 27, 2003 | 06:56 PM
1RawTA's Avatar
I found it, took out the pcm and the mount and it was right here, ran the wire through everything was good, started it back up stalled once, then idle like crap for a min or so, then it was fine. is there anything else i should have done for the ldle relearn?
