FAST 90 w/ my setup
Setup is LS6 intake
stock 2000 injectors
228/230 cam
full bolt on's
100 shot n20
n20 tune
Anyways I purchased a FAST 90 in take and TB recently with the plans of porting it and painting it. A set of heads was being considered with some bigger injectors.
Well after some some cash money consideration and the simple fact of needing a beefier rear end, im going to put the heads on hold for now.
So basically I know that the current injectors I have are dang near maxed out. So if I were to put the 90 on w/o heads I should go ahead and get some bigger injectors ( 36lb ). The problem Im having is I doubt doing this w/o the heads is going to yield me any sort of gain. So i guess the q's I am asking is should I wait on the 90 till I can afford the heads, or will it give me enough gains to justify the cost of install and tuning.
In the mean time I do plan on purchasing a racetronics pump kit, and bumping the shot to 150 to feed my needs
