no spark please help
Old Dec 23, 2008 | 06:37 PM
turbo408stroker's Avatar
Default no spark please help
i have a 99 camaro an an o4 gto. i put a 383 in the camaro an now i have no spark. i cheacked all the normal stuff grounds and fuses. it cranks but no spark i have power to the coil wires an ground the the coil wires as well as to the injector wires. my security light is not on. new plugs new wires new sensors. i even thought maybe a bad crank sensor so i swaped it with the goat an still no spark. could my computer be bad? i no it posibl for the coils to go up but the motor ran when i took it out. all my grounds are ground good my heads have good ground. any ideas please help so the goat can sleep for the winter. thanks
Old Dec 23, 2008 | 09:07 PM
Build #1's Avatar
Sounds like a bad ground......LOL anyway sounds like it needs a Tech 2 put on it. Thats all I got, to many variables.
Old Dec 25, 2008 | 09:58 PM
blackLS1m6's Avatar
Do you have a crank signal and cam signal?
Old Dec 26, 2008 | 02:43 PM
Silver_TransAm's Avatar
I was going to say crank sensor, but since you replaced already check the cam sensor. Just recheck all connections and make sure a wire did not get pinched somewhere, especially right behind the intake where the cam sensor wire could of got stuck between the trans and engine.
