installing z06 maf
Old Jan 3, 2009 | 03:23 AM
cals400ex's Avatar
Default installing z06 maf
ok, i want to install a z06 maf to match my 85mm Fast Toys lid and fast intake. i already have the iat installed in the air lid. is there a plug and play connector that will work since i already have the iat installed in the lid? i prefer to not splice/solder. i came up with this connector only:
http://paceperformance.com/index.asp...OD&ProdID=8139
Old Jan 3, 2009 | 03:27 AM
jsteele90's Avatar
looks like the right thing
Old Jan 3, 2009 | 03:39 AM
noriceinside's Avatar
actually thats the one you'd use if you werent installing the IAT in the lid. you need the other one. i cant find it now...
Old Jan 3, 2009 | 07:39 AM
the_merv's Avatar
Damn, $40 for that little piece..fck.
I put the Z06 MAF in my Car, wired the 5-Wire Connector to it. I used the 3 from the Stock MAF Conector, and the 2 from the IAT Connector.
Old Jan 3, 2009 | 08:14 AM
BadBandit69's Avatar
that looks like the caspers piece judging from the part number. Not sure if caspers electronics is still a sponsor here, but it might be a lil cheaper if you order directly from them.
Old Jan 3, 2009 | 09:07 AM
01Z0H6's Avatar
Here you go.. this is the one i used. The Z06 MAF has the IAT sensor in it.. plug the hole in the lid with the sensor, or a grommet and just don't plug it in. Save yourself some money...http://www.currentperformance.com/Ac...iring_acc.html
Old Jan 4, 2009 | 02:33 AM
cals400ex's Avatar
i think i can leave that iat in the lid and use the part that is $15.95 on that link you just sent me. what is the downside of this?
Old Jan 4, 2009 | 02:45 AM
ZMONSTER!'s Avatar
So wait you cant just plug an 85mm MAf in and be good? you have to run an adapter?
Old Jan 4, 2009 | 03:36 AM
the_merv's Avatar
^^If you get the Connector for it, you can re-wire it like I described. That is how I did it and mine is working fine.
Old Jan 4, 2009 | 02:28 PM
z28241's Avatar
Hey PewterY2kZ28, Again i asked this on another post, i went to that site, doesnt state what year that vett 85mm maf will work on, my understanding is 98-00 are different for 01-02 ls1's. Also do you know if those maf's new or used or reconditioned?
Old Jan 4, 2009 | 07:14 PM
colews6's Avatar
why doesn't ft over these harness as an option to the lid?
Old Jan 4, 2009 | 08:56 PM
TORCHD 02 TA's Avatar
hey this is what your looking for? PM me and i can get the link for you
Old Jan 5, 2009 | 01:20 PM
colews6's Avatar
what do you do with the iat plug if you don't need it with the zo6 maf.
Old Jan 5, 2009 | 01:46 PM
the_merv's Avatar
^^Depends on how you Wire it. Some people buy the piece pictured above your post and keep their IAT. I was able to get the Connector with my MAF, so I wired it to use the IAT that is in the MAF Sensor.
Old Jan 5, 2009 | 11:09 PM
cals400ex's Avatar
i found this on caspers too. i was thinking it was around $25 if i remember correctly. i think this is what i will do instead of plugging the lid and buying the other connector with the iat on it. i don't think there is any downside to this.
Old Jan 5, 2009 | 11:22 PM
Actually it is not from Caspers. And where i can get it from it is $15.95
Old Jan 6, 2009 | 09:03 AM
01Z0H6's Avatar
Refer to my link above... it is the one pictured, and yes, it is $15.95..
With regard to "Z28241's" post... Yes, they are different, you want the 02 and up. The ones on Ebay that i purchased mine from are from 05-06 models and are "new".. mine was under $75.00 shipped to my door.
GL..
