What is the vacuum box (cylinder) at the front??
Old Jan 21, 2009 | 06:10 PM
WS6 Canada's Avatar
Default What is the vacuum box (cylinder) at the front??
On a 01 TA on the passanger side front frame rail there is a black cylinder box thing that has a vacuum line going to it from the hvac??
What is it and can i remove it??
Thanks
Old Jan 21, 2009 | 06:48 PM
deadmanTA's Avatar
That's the vacume resevior. I moved mine into the fender, I beleive it helps switch the vents faster when your at low vac. I left mine because it doesn't really weigh even a pound and I moved it so it's not in the way.
Old Jan 21, 2009 | 07:10 PM
nemss1's Avatar
yup, youre exactly right. it does help the vents switch faster. removed all that crap when i deleted A/C/heat
Old Jan 23, 2009 | 06:20 PM
WS6 Canada's Avatar
I still have heat, no air, so....... can i remove it without any troubles?? The speed the vents move is no matter to me.
I will only need heat on the really cold days at the track to defrost the window.
Other than that i will have on the face vents for cooling.
Old Jan 23, 2009 | 06:25 PM
nemss1's Avatar
yes u can remove it. will not cause any probs. vents just dont respond as fast
Old Jan 23, 2009 | 06:28 PM
WS6 Canada's Avatar
thanks
cw
Old Jan 23, 2009 | 06:37 PM
nemss1's Avatar
no prob man
