need help with manifold
Old Feb 4, 2009 | 10:10 PM
strasser_3's Avatar
Default need help with manifold
How do you get the sensor out of the back of the ls6 manifold. it turns just a inch maybe and wont pull out? HELP
its the one at the very top in this pic.
http://rides.webshots.com/photo/2895...02719570LkKBud
Old Feb 4, 2009 | 10:19 PM
bczee's Avatar
This is for the MAP/Vacuum line right ?
As far as I have read and found, it is not a replaceable part. Could not find a deal that could find a part number to replace it. And no one has been able to post how to remove and replace. I broke the tab that holds the MAP on before. I just zip tied it in place and then just swapped in a LS6 intake.
You might be able to use a long screw driver from the inside of the intake to release the tabs holding it on. Let us know if anything works.
Old Feb 4, 2009 | 10:24 PM
strasser_3's Avatar
well thanks for the help. also I just ordered a fast 90 so will it already have this or is this something im going to have to buy?
