LS6 intake help!
Old Feb 11, 2009 | 09:40 PM
2002 SS's Avatar
Default LS6 intake help!
i just recently bought a LS6 intake from a user here. when i receieved it, it was broken . I believe the MAP sensor is gone and the piece where the brake booster hose it connected to. So is there any place to get the MAP sensor or just the whole circular back part? any input would be appreciated... thanks!
Old Feb 11, 2009 | 09:57 PM
fast377's Avatar
The map sensor goes into that little round hole (you use your old one). And it's hard to tell from the pic, but is the large vac port broken? If it is, it looks like there is enough left to slip some hose on...but it's blurry. For the most part though, it looks fine.
Old Feb 11, 2009 | 10:38 PM
2002 SS's Avatar
yes, sorry bout the pics but its like half of the vac part is broken off. i doubt i could fit the hose...
Old Feb 11, 2009 | 11:31 PM
2002 SS's Avatar
so i could re use my MAP sensor from my LS1 intake?
Old Feb 12, 2009 | 06:02 AM
fast377's Avatar
Yes, that is what you are supposed to do. Just make sure the rubber seal comes out with your LS1 map. For the vacuum fitting...I don't know. You might try glueing some material on there or something. I don't know of any way of replacing that whole piece.
Old Feb 12, 2009 | 07:58 AM
garys 68's Avatar
I've tried to remove that plug, as have others. Some say there may be a couple clips that hold it in place. You might be able to get access to these through the TB opening. If that works you should be able to replace it with your old one.
If not, I've rebuilt plastic parts (obsolete magneto cap) using epoxy. Just clean the part really well with acetone, make a form with tape, then fill with epoxy. You can drill out the port after it dries and clean up the outside with a file or dremmel.
Old Feb 12, 2009 | 07:35 PM
TRANSdAMn 2k's Avatar
Curveball TECH
Did you know it was like that when you bought it? If not I would send that **** back and pick up another one.
