Removing ASP Underdrive
Old Feb 14, 2009 | 10:51 PM
91ZLS6's Avatar
Default Removing ASP Underdrive
Hey Everyone.
Ive been trying to remove the ASP underdrive off our spare LS1.
I tried a 3 claw puller grabbing on the back and pulling, got no where, put 3 bolts on and used a 3 claw grabbing on the heads, and then the puller arms all stressed and snapped.
Our 3 bolt puller wont reach the bolts, as in it doesnt span wide enough.
Is there any other options? This things moved maybe .050" of a inch.
Im ready to throw this motor through a wall
Help!
Old Feb 15, 2009 | 06:24 PM
Grimes's Avatar
You have to find a puller that can accommodate three bolts that fit into the pulley. There's no other way to get it off.
Old Feb 15, 2009 | 07:46 PM
HavATampa's Avatar
Buy one of these "quality" pullers from Sears and get you 3, grade 5, 5/16-24 fine thread bolts to screw into the ATI pulley. Mine didn't come with bolts to fit the ATI.
http://www.sears.com/shc/s/p_10153_12605_00947626000P
Old Feb 16, 2009 | 10:43 AM
RZRSEDGE's Avatar
^^^^^^^ That's the only one that I've used and it works like a champ! WAY easier to get off than the stock pulley. Good luck!
