broken header bolts HELP PLEASE
Old Feb 17, 2009 | 01:27 PM
qwickLT1WS6's Avatar
Default broken header bolts HELP PLEASE
I broke two header bolts on the driver side head while trying to put on lt's. Does anybody have any expierence or words of advice?
Old Feb 17, 2009 | 04:18 PM
ScrapinBye's Avatar
I'm dealing with the EXACT same issue, w/ two wrung off bolts on the drivers side. there is only about 5 1/2" between the motor and the strut tower, so drilling them out proves to be a little tricky. I tried a Grabit drill bit with a 90 degree drill and it was still too big to fit in there. Only other thing I can think of (w/o pulling the entire head) is to buy a flexible drilling shaft. Lowes sells them as an attachment to a Dremel tool. OR take all the other bolts out of the header flange, pry it back and stick a wedge in there, and see if you can get a pair of vice grips on the broken off bolt. I'd be curious too to hear any other suggestions. Those damn Pacesetter bolts are about the shittiest fasteners I've ever come across.
Old Feb 17, 2009 | 04:26 PM
all the other bolts are out, and the header is out of the way, there's one sticking out in the middle and one in the very far back
Old Feb 17, 2009 | 06:32 PM
Unertl42's Avatar
try and screw a nut onto the broken bolt and weld it.
