Cranks but wont turn on
Old Feb 18, 2009 | 06:23 AM
99tankta's Avatar
Default Cranks but wont turn on
1999transam car will crank but it will not turn on i just finished doing an a4-m6 swap with m6 wiring harness...new rebuilt motor... everything is connected.. the pcm is still on a4 tune....
cars has spark, fuel pump comes on, i changed the crank sensor, i swwitched ignition relays <-- when i did this the car was on for a couple of seconds but turned off...i tried to turn on the car again and it would just crank and i had a little bit of back fire come out of the intake...has full tank of gas
any ideas on what it could be....
Old Feb 18, 2009 | 06:37 AM
99tankta's Avatar
would cam sensor be the problem or reluctor wheel
