Please Read!!! Car won't start. gotta be at work at 7am
Okay I'm pretty sure it's my lock cylinder. I went outside, sat in the car, and tried to start it like normal. None of the gauges came on and the starter wouldn't engage. Battery is fine, all fuses are fine. You know how when you stick the key in the car makes a quick dinging sound and when you turn it to accessory the dinging slows to a more drawn out ding? Well it doesn't do that. When I turn the key to accessory the radio stays off, the blower motor doesn't work, the gauges don't illuminate, and the fast paced dinging continues. This sound like the lock cylinder to you? If not then what? If so then when I buy a new lock cylinder how do I configure it for my particular passkey setting?
Actually now that I think about, if the bcm fried, wouldn't my locks stop working? I definitely used my keyless entry remote to lock my doors and it armed the alarm. I remember doing this because my car is in the parking lot at some bar down the street from my house.
I did disconnect it. At first I thought it was a loose terminal because I lent a buddy my battery yesterday so I thought I just didn't tighten it back up good. Is there any way this could be the lock cylinder?
if your not getting power anywhere, have you checked your battery for enough volts. if it is your bcm could still be just a little damp
Well as of yet, I haven't been to sleep all night, I'm missing work, and my car still won't start lol. The battery is fine though. The car just won't go to accessory mode, much less turn over. It doesn't click nor do the interior lights dim when I try to start it.
I originally thought maybe the battery took a ****. I went to a local parts store to buy wax, came out and got in the car and the car wouldn't start. The car wouldn't do anything. I went back in the store and bought a brand new DELCO battery and put it in right there in the parking lot and still nothing; so then I thought it was the clutch switch, Im swapped it from my WS6 and still nothing. Ended up having it towed home.I had a locksmith that does on-location repairs come to my home and he brought a small by-pass box that by-passed the VATS system and BAMM! the car started right up. He said its fairly common that one or sometimes both of the wires break and they can't be repaired; you have to replace the entire cylinder and he gave me two brand new ignition keys too.
yeah the repeated action of tilting the steering wheel up and down over the years works those wires pretty hard. I'd say new lock cylinder, but not sure cause your security light isn't on. Hopefully you can get it worked out before missing any more work.
