intake wont come off
went out to check the car today since it was getting dark when i put it back last night and... big puddle of oil under the car as well as a line out to the shed and a puddle outside the shed i assume where the car sat while i got out and opened the door. from what I could see its probably coming from the sending unit... probably put it in wrong?? is this possible? it threaded in nicely and we snugged it down pretty tight... i assume it would leak if its too loose but what about too tight??
turned the key on to unlock the wheel to move the car out onto the pavement so i could jack it up and also discovered some fuel on the front end of the drivers side fuel rail at the plastic piece. i turned the key off wiped the rail and turned it back on to charge the system and the end of the rail just very slowly became damp with fuel and would have probably taken a couple minutes to make a drop... so are my fuel rails shot now too...
ne body know of problems with getting the oil sending unit in? and what do I do about the fuel? Luckily ive got another vehicle i can drive so I can get back down to school.
Please help...
hopefully your doin this to your '99. if your swapping in an LS6 intake. jus makin sure you know the '01-'02's have the ls6 intake stock.
Please help...
To avoid breaking the oil pressure sending unit, I lifted the intake straight up, then put my arm under the intake, and wrappe my fingers around the back of it and pulled it forward to be sure that I put no pressure on the oil pressure sending unit.
but i wanted to know why do you need to hold the bolts up in the back of the intake? im about to do the install in a couple of weeks.,,,
