throttle cable
Old Feb 21, 2009 | 02:39 PM
kilgore's Avatar
Default throttle cable
i have a ls6 intake manifold and a 85mm throttle body. when i connect the throttle cable to the new throtle body the cable makes the throtle body open up a little bit. how do i lengthen the cable or can i get rid of the spacer that they gave me?
Old Feb 21, 2009 | 04:10 PM
DaveX's Avatar
Not sure if this will solve your problem but the cable is adjustable for length. There is a black box looking thing in the cable about midway between the firewall and cruise control box (if you have one). You pull out a clip, slide it back and forth to adjust, and reinsert the clip.
