Which Do I change Idler Pulley or the Belt>?
and If you threw a belt...it was the belt going bad...not the pulley....
when they get bad they get stretched out of wack....no tension=squeak,squeak,squeak...
IF it is a pulley...it will be one of the freewheeling ones...and you should spray with silicone..not wd-40...take the plley off to spray it...be careful not to get any on the part where the belt rides...
Subject: Technical - Accessory Drive Squeak (Replace Idler Pulley)
Source: Chevrolet Service Bulletin
Number: 99-06-01-007
Models:
1997 - 1999 Chevrolet Corvette
1998 - 1999 Chevrolet Camaro
1998 - 1999 Pontiac Firebird
with 5.7 L Engine (VIN G - RPO LS1)
Condition:
Some customers may comment on a squeak noise coming from the engine or accessory drive while the engine is running . This squeak may vary in volume and may be heard inside the vehicle with the windows up and the radio on.
Cause:
The idler pulley dust shield may distort during assembly due to torquing of the mounting bolt. This distortion may cause the idler pulley dust shield to contact the bearing race and the pulley resulting in the squeak noise.
Correction:
A new idler pulley assembly is available with a thicker dust shield to prevent the distortion of the dust shield. The previous dust shield thickness is 0.61 mm. The new dust shield thickness is 1.37 mm.
Important
Do not over-torque the mounting bolt or the condition may reoccur.
Do not use pneumatic or electric tools for installation of the idler pulley assembly.
Tighten
Torque the idler pulley bolt to 50 N·m (37 lb ft).
Parts Information
Part Number
Description
12564401
Idler Pulley Assembly
